If you plan on setting up RAID (Either SCSI or IDE) in the future, get the 400 W. AMD boards like to have lot's of juice and they get very picky if you have a bad P/S. As stated above, make sure that it is name brand, Antec, Enermax, Sparkle all make good P/S. A good Battery Backup system, (UPS) is also a must to protect your system. If you buy the greatest P/S in the world, then do not get a UPS for it, your system will still be sesseptable to damage from bad power.
If it works for you then don't fix it.
