Archived from groups: comp.sys.laptops,alt.sys.pc-clone.compaq (More info?)
I have installed Win98SE on a Compaq Armada M700 laptop but cannot load
the drivers for the internal NIC. The NIC is a modem/NIC combo (part no.
1456VQL10H(INT)). I have downloaded and tried all of the drivers listed on
I have also tried the SP12942 driver d/l from driverguide.com which is
listed specifically for the 1456VQL10H combo NIC -- all without success.
In Windows, under Control Panel/System/Device Manager, There are modem
related devices listed under Network Adapters for which Windows has loaded
the drivers but there are no NIC/Ethernet related drivers there.
Under Unknown devices, there is an entry 'PCI Communication Device'
listed. I have tried loading all the above drivers for this Unknown
device, without success. It is unclear to me why, if this device is the
NIC component of the combo card, it should be listed here rather than
under Network Adapter.
The BIOS config. does not appear to have a NIC enable/disable option...
Any ideas?
Thanks
Tom Crane.
Tom Crane, Dept. Physics, Royal Holloway, University of London, Egham Hill,
Egham, Surrey, TW20 0EX, England.
Email: T.Crane@rhul.ac.uk
Fax: +44 (0) 1784 472794
What OS was originally installed?
HH
<UHAP023@alpha1.rhbnc.ac.uk> wrote in message
news:2heuchFc3cffU1@uni-berlin.de...
> http://h18007.www1.hp.com/support/ [...] 09.html#17 >
> Any ideas?
> Thanks
> Tom Crane.
Hill,
I don't know -- it came with an erased HD ;-(
Tom.
> HH
news:2hf49dFbq4h4U1@uni-berlin.de...
> Tom.
> > HH
Hill,
Works wonders when you read the page
>Did you try the driver from Compaq? It's here:
>http://h18007.www1.hp.com/support/files/Armada/us/download/7792.html
>HH
>> Tom.
>> > HH
>Hill,
Indeed. I've tried the NIC diver on the URL below -- it is a link
from their main list of drivers for the M700 which I gave in my first post.
The thing that puzzles me is that the Windows device driver manager identifies
no Network Adapters corresponding to the Ethernet card when it boots.
If the H/W is present it should see it and prompt for the correct driver,
if its not present on the Windows installer CD. Agreed?
Tom
>>HH
Not always. Software (controllerless) modems often are not detected by
Windows at all, or at best as an "unknown" device in Device Manager. That
may be true of your combo card as well.
HH
news:2hjp99Fdfv7hU1@uni-berlin.de...
> > Works wonders when you read the page >
post.
identifies
> Tom
> >>HH
Hill,
I have the same adapter (1456VQL10H(INT)) in an Armada M300. Still
can't get the darn thing to work. Has anyone gotten it to work. If so
are there any tricks to it?
No. I gave up re; Ethernet and bought a cheap PCMCIA card instead. The
modem part of the combo works OK.
Tom.
Are you sure the mini-PCI card actually _has_ a NIC ? ISTR seeing some
that have the pysical RJ45 socket, but wired to nowhere. I'd guess when
shipped the card would have had a blanking plug fitted, which has since
gone astray.
In case its still of interest, I'll probably be breaking a M700 shortly.
(internittent mobo fault :-/ ). One of the items would be the mini-PCI
ethernet/modem combo (which worked fine with win98se - ISTR its an Intel
NIC chipset). Just trying to get some money back on it ...
> gone astray.
The M700 shipped with an Intel 56k/NIC combo mini-PCI, so unless it's
defective, it should work. It's not supported by the Win2k drivers (not
sure about XP, never ran that on my old M700), but Compaq has the proper
drivers for it.
