Archived from groups: alt.internet.wireless (More info?)
I have my cable modem connected to a Netgear RP614 router in a small office
off our den. I have two cables run underneath the house from there - one to
the kids' room and one to my "real" office in the back of the house. In the
kids' room there is a Dlink DI614+ wireless router, which I want to function
only as a hub and wireless AP. I plugged the network cable into one of the
router ports, turned off DHCP, enabled wireless functionality, and
everything has been working fine - except that the speed on downloads (on
even the wired computers connected to the Dlink) is about 1/5 the speed of
downloads elsewhere, including the computer in my real office, which is
behind an Intellinet 8-port switch, along with a Vonage phone adaptor. Last
night after noticing the much slower speeds of the computers in the kids'
room, I disconnected the Dlink and plugged one computer directly into the
network connection in that room, and the speeds jumped up to match the
others in the house.
The Dlink is definately drastically reducing network speed. Is this normal
when using a router in this fashion, or do I possibly have a configuration
error?
>error?
No, that's not normal. However, you don't supply a single number that
can be used as a sanity check. 1/5th the speed of what? Speed
downloading from the internet or from computer to computer on your
LAN.
Which DI-614+ ??? Rev A has 2 antennas. Rev B has 1 antenna.
I'm guessing one of your devices is set for 10baseT instead of
100baseT, or that NWAY negotiation has failed between boxes. It's
also possible that you have wiring or connector problem with the CAT5
cabling.
It's a fair assumption that everything except what is connected to the
DLink is working normally. That leave the DLink DI614+ or some of the
cables attached to it. Try borrowing the Intellinet 8 port switch
(model number?) and replacing the DI614+ with it for a while.
