Hi everyone, I have a big problem in my hands. I bought an Antec True550 and after almost 2 months of use something terrible happened, something burned inside when it made a big noise and the system shuted down.
Then I had to decide what to do, to RMA it back or to try fix it myself. I have to mention that I got this PSU through many transactions and freights since it's not available in my country, nor any quality PSU. I decided to try fix it myself, since many freights for the RMA would cost me the half I paid for it (just the same a new one cost in USA) and a lot of time.
So I found that the fuse was blown and decided to change it, but for my big deception as soon as I gave it power another blown fuse I had. I realized by testing the outputs before that all outputs are in shortcircuit with a difference of less than 50 Ohms but thought that that was simply a protection for short circuit since the manual says that all outputs are set to ground.
So now I think that maybe something else is wrong in the PSU and that I most change that part, that's what my message is intented, to request any kind of help, maybe a circuit diagram of this power supply , suggestions to find a burned devices, etc. I've already taken a look thoroughly and not a single capacitor or transistor seems burned, but maybe I shoud also check them with a multimiter.
Any suggestion to check transistors?
Please help! I would really appreciate real help.
