Power supply connectors
Last response: in Components
Related ressources
If you look <A HREF="http://usa.asus.com/prog/spec.asp?m=P4C800-E Deluxe&langs=09" target="_new">here at the ASUS website</A> it says under Internal I/O Connectors that there is a 20-pin ATX Power connector and 4-pin ATX 12V Power connector on the board so I would assume that you need them both. Seems like most motherboards coming out these days need all the power they can get.
As for the power supplies, ask the store where you are getting them from. They should know what sort of connectors the power supplies have or can find out quick.
<font color=blue><b>Purchase object A, install object A, curse object A, repeat...</b></font color=blue>
You need to use it, and all Fortron power supplies have had it for at least 2 years now.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Ask the community
