Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > System Restore Is Not Able to Create a Restore Point
Forum Windows XP : Windows XP General Discussion - System Restore Is Not Able to Create a Restore Point
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I'm using Windows XP Pro Home Edition (Service Pack 2) on an HP Pavillion
a250y desktop. I have noticed recently that there are no system restore
points on my computer. A check of the Event Viewer seems to indicate that
my computer has unsuccessfully tried to create five system restore points in
the past four days. If I right-click on any of the unsuccessful system
restore attempts listed to view the error properties and then click on the
hyperlink associated with the error properties, I get a message indicating
that System Restore will automatically restart if I manually create a
restore point. However, when I try to do this, I get the message contained
in the subject line. Does anyone know of a way to fix this problem? Thanks
for any suggestions.
Sponsored Links
Chris, check at Kelly's http://www.kellys-korner-xp.com/xp_abc.htm
Select S and scroll to System Restore.
"Chris Sherlock" <chris_sherlock@mindspringnospam.com> wrote in message
news:k7FYd.1774$qf2.829@newsread2.news.atl.earthlink.net...
> in the past four days. If I right-click on any of the unsuccessful system
> contained in the subject line. Does anyone know of a way to fix this
> problem? Thanks for any suggestions.
Reply to Anonymous
Hi Chris,
Look to see if any of the Source and EventID's in Event Viewer match
the errors in this article.
You Cannot Create a Restore Point with a HighPoint Driver Installed
http://support.microsoft.com/?kbid=322246
More information.
System Restore fails to create an automatic restore point
http://home.earthlink.net/~mvp_bert/html/srauto.html
Regards,
Bert Kinney [MS-MVP DTS]
http://dts-l.org/
> an HP Pavillion a250y desktop. I have noticed recently
> that there are no system restore points on my computer. A check of
> the Event Viewer seems to indicate that my
> restore points in the past four days. If I right-click
> on any of the unsuccessful system restore attempts listed
> message indicating that System Restore will automatically
> restart if I manually create a restore point. However,
> when I try to do this, I get the message contained in the
Reply to Anonymous
Anonymous, you can't be using "Windows XP Pro Home Edition," because there's no such thing.
Reply to maxxfordham
There are 826 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
