Howdy all.
I am looking for a good-to-high quality PSU for my machine, but it also has to be quiet. Does anyone have any suggestions?
-Thanks for your help
DFI Lanparty NFII Ultra Rev. B
AMD Athlon XP 2500 Barton
Geil 512MB PC3200
ATI Radeon 9800 Pro 128MB
WD 120GB SATA HD
Women--can't live with them, can't have heterosexual same-species intercourse without them.
i've got an antec true power 350 and i think it is quiet. i hear that fortron psu are good quality and quiet. if i remember correctly, you should look for one that has a 120mm fan - those are the quiet ones. i think they are around 40 dollars.
I recommend the Fortron Source 350W unit:
1.) It's inexpensive ($42 at newegg)
2.) It has a VERY quiet 120mm fan (adjustable speed)
3.) It exhaust heat from your CPU better
4.) Fortrons are rated at continuous duty, not peak, the 350W unit outputs over 400W by other companies standards.
I tested one on my very high demand system (P4 2.6C at 3250MHz, several hard drives, SCSI cards, 1GB PC4000, etc) and it worked great.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
