How to access my sound card mixer controls?
Bobby
287
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I need to access the sound card mixer controls to fix
something for the Sound Recorder on my Windows XP.
G
Guest
Guest
Bobby;
Start.Control Panel/Sounds
From there you should be able to access all your sound card options.
Check your manual and/or the manufacturers website since all sound cards are
different.
Jupiter Jones [MVP]
http://www3.telus.net/dandemar
In memory of our dear friend, MVP Alex Nichol
http://www.dts-l.org
"Bobby" <anonymous@discussions.microsoft.com> wrote in message
news:02ac01c53096$b8061080$a501280a@phx.gbl...
G
Guest
Guest
To find the mixer built into Windows XP:
Control Panel - Sounds and Audio Devices - Volume tab - Advanced button.
To find the mixer that came with the software for your sound card:
Consult the software's Help file or user guide.
Modem Ani
Bobby
287
When I go to the "Recording Control"...the column that
says "recording" is not able to be moved.
>-----Original Message-----
Advanced button.
sound card:
>Modem Ani
message
G
Guest
Guest
I don't have a slider called Recording Control on my mixer, so I'm afraid I
can't offer any advice.
Modem Ani
news:03e301c530b4$adbe8d00$a501280a@phx.gbl...
> Advanced button.
> sound card:
> >Modem Ani
> message
Bobby
287
"Recording Control" is what the window is labeled...the
sliders that I have are "Recording, Stereo Mixer, Mic,
Line In, CD Player".
>Modem Ani
message
tab -
>> Advanced button.
>> sound card:
>> >Modem Ani
>> message
fix
G
Guest
Guest
>>Modem Ani
> message
> tab -
>>>Advanced button.
>>>sound card:
>>>>Modem Ani
>>>message
> fix
This is in reference to Windows Mixer (aka Volume
Control). In the Options area, click on the recording
button. In the list below, check or un-check the items you
choose. Below each item displayed after closing options,
check which control you want to use. Please note that the
slider will only operate on the one(s) checked.
If they won't, you may have some file fragmentation or
corruption, causing it not to function.
Lester Stiefel
In Romans 1 there are qualities of Unregenerate man listed
which describe him in the last days.
Is your quality found on this list??
Bobby
287
labeled...the
>>>Modem Ani
>> message
>> tab -
>>>>Advanced button.
your
>>>>sound card:
>>>>>Modem Ani
in
>>>>message
>> fix
you
the
>Lester Stiefel
listed
To: Lester Stiefel
How do I fix the file fragmentation or corruption?
