Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I received a zip file from a software manufacture. It has a total of 15
files in it. When you open or extract the files using the WindowsXP
Built-in Zip Program, it only shows 14 files in the folder window and will
unzip only 14 files.
When using a third-party zip program such as WinZip or PowerArchiver both
shows all 15 files in the folder window and will unzip all 15 files.
The file name is "M5 Pages, Components and Help.msi" which is unusual in
that it has a comma in it.
Why will the WindowsXP Built-in Zip Program not see this file? Is there any
way to correct this problem other than to buy a third-party zip program?
| Thanks
| JW
"Carey Frisch [MVP]" <cnfrisch@nospamgmail.com> wrote in message
news:u%23ASgBVMFHA.3988@tk2msftngp13.phx.gbl...
> Did you try to right-click on the downloaded file and select "Install"?
> Carey Frisch
> Microsoft MVP
> Windows XP - Shell/User
> Microsoft Newsgroups
> Get Windows XP Service Pack 2 with Advanced Security Technologies:
> http://www.microsoft.com/athome/se [...] hoose.mspx >
will
both
any
> | Thanks
> | JW
"jw" <jw@hotmail.com> had
writtennews:eCBPELVMFHA.2988@TK2MSFTNGP14.phx.gbl:
> I got the answer and it works
> "Hotfix 329048 Causes a Zipped File Not to Be Shown If the Name
> Contains a Comma" http://support.microsoft.com/?kbid=813942 > Thanks
> JW
Thank you! I'm glad you posted where to find the solution. I too was
having problems.
Barney __________________________
Wisdom from the sleeping dogs!
