feketegyula1 :
CALL OF Duty3 játék menete közben bejön egy error relable command buffer overflow felirat. Mi a teendő ilyenkor, hogy folytathassuk a játékot???
You must not be aware that this is an English-language forum?
Here's your help though, it was just down this page, but oh well...
"The solution is not to go along the street but jump inside the bulding with broken windows on the right. There will be several enemies there, you will kill them, exit the building on the other side and the checkpoint will save. Going along the street in the open causes this glitch."
Next time use some common sense and do some searching and also use English. I hope you can also understand this post.
