Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Optimal throughput speed on a 802.11b wlan
Forum Wireless Networking : Wireless General Discussions - Optimal throughput speed on a 802.11b wlan
Archived from groups: alt.internet.wireless (More info?)
I'm connected to the internet via optical fiber. A friend let me put
the line and modem inside his garage and a 19dbi parabola on the roof
to connect to my home 4km away. In the garage the modem is wired to a
Buffalo WHR2-G54 router, the router wired to a Buffalo WLM2-L11G
(802.11b only, the kind with cards inside) AP. The AP is connected to
the parabola with 5 meters of some kind of pretty fat coaxial (sorry I
don't know the specs). At home I have a 24dbi parabola connected to a
Buffalo WLM2-L11G AP again connected through 5 meters of fat coaxial.
There is clear line of sight as we are both on top of hills. At the
modem throughput is around 15-20mbps. Here at home I get up/download
speeds of around 3.5-3.8 mbps pretty consistantly. I'm wondering that
with 11b shouldn't I be able to get 7-8 mbps throughput at a distance
of 4km?
As an experiment,I bought 2 used Buffalo WBR-G54 routers and loaded
them with Sveasoft Alchemy firmware. I set them in AP mode, upped the
transmission power to 50-100mw and put them in place of the 2 Buffalo
WLM2-L11G AP's. Doing this throughput actually went down to about 2mbps
in both 11b and 11g mode.
I'd like to get more speed somehow. Any suggestions?
Sponsored Links
>of 4km?
Nope. An 802.11b 11Mbit/sec connection will yield about 4Mbit/sec
thruput. By juggling the packet timing, I've squeezed about
5Mbits/sec out of such a connection.
Did you try it a normal (35mw) power output before you started messing
with the tx power?
If you're going to play point to point link, turn *OFF* the 802.11b
compatibility mode in the WBR-G54 router. If it hears an 802.11b
signal, it will slow down.
This is stolen from an Atheros PDF at:
http://www.atheros.com/pt/athe ros_range_whitepaper.pdf
with some additions and corrections by me.
Non-overlapping Modulation Max Max Max
Channels ------- | Link TCP UDP
802.11b 3 CCK 11 5.9 7.1
802.11g (with
802.11b) 3 OFDM/CCK 54 14.4 19.5
802.11g only 3 OFDM 54 24.4 30.5
802.11g turbo 1 OFDM 108 42.9 54.8
802.11a 13 OFDM 54 24.4 30.5
802.11a turbo 6 OFDM 108 42.9 54.8
If 802.11b works, 802.11g should work better. My only guess is that
something is wrong with the RF connections to the antennas. Possibly,
one of the new radios is defective in some way.
Playing with the numbers and run a sanity check:
http://www.terabeam.com/support/calculations/som.php
TX power = +15dBm
TX coax loss = 2dBm (5 meters LMR-400 + connectors)
TX antenna gain = 19dBi
Distance = 4km = 2.5 miles
RX antenna gain = 24dBi
RX coax loss = 2dBm (5 meters LMR-400 + connectors)
RX sensitivity = -79dBm (for 24Mbits/sec connection)
fade margin = ????
I get a fade margin of 20.8dB which is about the minimum that can be
made to work reliably. It should work according to my numbers. With
a 24Mbit/sec OFDM connection, you should get about 12Mbits/sec
thruput, which should be adequate. Try setting the access point speed
to 24Mbits/sec OFDM instead of "auto".
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
AE6KS 831-336-2558
Reply to Anonymous
I really appreciate the response and the numbers. I really don't
understand enough to do the calculations myself. No, I guess I didn't
try Alchemy in normal power output. The Buffalo APs are connected up
now, but I'll try your suggestions about the power and settings in the
alchemized WBR-G54s when it stops raining and thundering outside (I
probably shouldn't be on line now but have been pretty lucky up to now
in weather like this).
You mentioned perhaps a problem with connectors or radios. Buffalo uses
mostly MC lucent connectors I think. Whenever I plug in a pigtail, I
always worry whether the plug is sitting properly in the jack. These
connectors don't seem so well designed. And radios in the WBR-G54, are
the radios on the Mini PCI card or the main board of the unit? I have a
couple of extra Mini PCI cards I could trade out and check if one's
defective.
Thanks again for your time.
Reply to Anonymous
There are 1094 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
