Burned floppy power cable.
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Burned floppy power cable.
I connect the IDE and the power, and procede to power up the machine...<SNIFF, SNIFF> What's that smell?? Holy cow, there's smoke!! And before I know it, I've burned the power cable going into the floppy! Well, after an autopsy of the cable, I noticed that I plugged it in with the left connector not connected to anything. So connecting 3 of the 4 connectors will short out the connection...
i cut out the burned section and insulate it with insulator tape.
The PSU is working fine.
Sponsored Links
should I continue using it?
everything seemed stable in MBM volt monitor.
fans spinning, not >5% fluctuation for all voltages...
Reply to terrencechoyo
LOL, you didn't JUST connect 3 out of 4 pins, you connected either your 12v (yellow) or 5v (red) wire to GROUND! And yes, that shorts out the wire to the GROUND wire and burns it.
Your power supply is probably fine. If you want you can chop that cable and try splicing in another.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Reply to Crashman
Yeah. Just continue to use it. Lesson learnt.
A fine day!
Reply to redface
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Burned floppy power cable.
There are 1222 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
