power supply problem?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - power supply problem?
Hello,
I recently bought a set of components to build a new Athlon XP system, but have ran into some problems.
I purchased an Athlon XP 2600+ processor, PCChips M848A motherboard, 512 MB Kingston DDR 333 Memory, and I'm using a Radeon 7500 board that I used in an older P3 1.2 GHz system I have been running on.
The case I purchased had a 400W power supply.
The problem is this, the system would boot up originally but would crash /w a blue screen before Windows would even install during the XP install process.
I thought it was a heat issue, so I bought compound and a copper plated heat sink to replace the heat sink that came with the computer, it didn't do anything. It still crashes.
But, I am able to run the processor at lower speeds; although something peculiar happens. The built-in AC97 sound has a high crackling noise, and there are graphical glitches - the start menu button has red spots, and red coloring is in other things such as when I loaded the Sims.
Since it is not a heat issue, I assumed maybe the motherboard was bad. So I went out and purchased a Soyo Dragon KT600 Ultra motherboard; the exact same thing happened - crackling sound through the on-board audio, constant crashes, and bizzaire graphics where some things have red spots/splotches.
So I took that motherboard back for a refund, seeing that the motherboard is not the issue.
I then went to the AMD website to double check power supply requirements. My 400W power supply does not have the same Amperage "maximum continuous" outputs as what they list for an optimal workstation.
My question, before I go out and buy an expensive power supply to test this out, is if this is the problem?
Again - the problems in summary are red spots/graphical glitches, audio that is crackled and hard to hear, as well as consistent crashing in where the computer automatically reboots itself or turns itself off at times.
Thanks for the help in advance!
Sponsored Links
By the way, the only other thing I can think of that would be the problem is maybe this is just a bad CPU? Is this possible as well?
Reply to brandon22
- 0 +
check the memory , download memtest86 to check , also try relaxing memory timings (3-3-3-7)
Reply to randy66
Thanks for the advice,
I lowered the memory timing settings as well as switched the stick out with another Kingston DDR 333 stick that I have, same thing is happening.
I also got another power supply today, again the same thing is happening. Luckily the store I purchased the products from have a good return policy, so I've gotten every bit back that I spent on the motherboard and power supply.
Anyway, I'm almost sure now that the problem is the CPU itself. I am going to be returning it for an exchange ASAP, hopefully this will solve the problem. I've literally checked every other possible problem out.
Reply to brandon22
sounds like video card problems with the display giving odd colors and such....the noises are another thing altogether, try running in barebones and see what happens, try with a different vid card as well...
Fat, Drunk, and Stupid is no way to go through life Son.
Reply to allanon1965
- 0 +
kingston ram?
heard that they have plenty of problems...
blue screen normal related to bad ram.
try install win98 to see if you succeed. if so then probably ram problem.
A fine day!
Reply to redface
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > power supply problem?
There are 796 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 demondrumer won the Freshman badge
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
