Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I have WIndows XP and system restore is not automatically creating 'SYSTEM
CHECKPOINTS' as it apparently is supposed to do and as my Windows ME does.
Does anyone know why? Is there something I must do to have XP do this
automatically without me having to do it manually?
Hi Gman,
Use the Event Viewer to investigate System Restore service errors. To
do this, follow these steps:
* Go to Start - Run and type eventvwr.msc and press enter.
* Click the Source tab to sort by name, look for "sr" and
"srservice." Double-click each of these services, and evaluate the
event description for any indication of the cause of the problem. Make
note of the Description, EventID and Source of these Event Properties
that show an Error or Warning, and post them here.
> creating 'SYSTEM CHECKPOINTS' as it apparently is
> supposed to do and as my Windows ME does. Does anyone
> this automatically without me having to do it manually?
Hi, Bert,
Thanks for the info. I can create restore points manually and can get the
task schedule feature to pop up the restore box when I want, such as at start
up or log in. Also, I can restore successfully. I checked the event viewer
and there is nothing there except that restore points were created by the
system when I installed a couple of software programs in the last few days.
You indicate that automatic restore points will not be created if the system
is not idle. Does the system decide to create an automatic check point at a
p[articular time or after a certain amount of idle time?
The other odd thing I noted with restore is that when one is typing in a
name for a restore point, but maybe wants to change something or correct
spelling, the cursor cannot highlight anything to delete, copy, etc. Not a
big deal, just a tad annoying due to inconsistent behavior between features /
programs and use of cursor.
I download a couple of the scripts that were listed, but I am not familiar
with scripts. What do I do now that I have downloaded and saved them to a
folder? LOL
Great website, BTW. Thanks for your help.
gman
"Bert Kinney" wrote:
> Hi Gman,
> System Restore fails to create an automatic restore point
> http://home.earthlink.net/~mvp_ber [...] rauto.html >
> Regards,
> Bert Kinney MS-MVP Shell/User
> http://dts-l.org/ >
Hi,
gman wrote:
> Hi, Bert,
> manually and can get the task schedule feature to pop up
> the restore box when I want, such as at start up or log
> event viewer and there is nothing there except that
> restore points were created by the system when I
> created if the system is not idle. Does the system
System Restore by default creates an automatic restore point every 24
hours and only when there is sufficient system idle time. If the
system is in use all the time it is turned on, or if there is a
application running that causes no idle time, automatic restore points
will not be created. Screen savers, stand by, or hibernation can also
prevent automatic restore points.
> is typing in a name for a restore point, but maybe wants
> to change something or correct spelling, the cursor
> behavior between features / programs and use of cursor.
> I am not familiar with scripts. What do I do now that I
> have downloaded and saved them to a folder? LOL
Download the XPSystemRestorePointFrequency.vbs script and remove it
from it's zip file to the desktop. Double click to run it. It will
show the number of hours the system is set to create restore points,
and allow you to change it.
>> Hi Gman,
>> service errors. To do this, follow these steps:
>> enter.
>> "sr" and "srservice." Double-click each of these
>> services, and evaluate the event description for any
>> indication of the cause of the problem. Make note of the
>> Properties that show an Error or Warning, and post them here.
>> http://home.earthlink.net/~mvp_ber [...] rauto.html >>
>> Regards,
>> http://dts-l.org/ >>
>>> automatically creating 'SYSTEM CHECKPOINTS' as it
>>> have XP do this automatically without me having to do it manually?
Hi, Bert,
Just wanted to inform you that the goofy Restore has now begun to create
automatic restore points without me having done a thing (been very busy and
wanted to wait until I had time to concentrate on problem). Can't understand
why, unless it has something to do with having a password. I did not have a
password before, but the Task Scheduler would not run a System Restore
scheduled task unless I had a password. So, I created one. It appears that
the automatic restore points began being generated around that time. I do
not have any restore task scheduled as it didn't perform the operation
without the restore window popping up and asking me to create a restore
point. Didn't want that; just wanted it to do it without me knowing.
Anyway, I'm getting the points now, but I wanted to report this to you and,
again, thank you for your assistance.
gman
> Hi,
> gman wrote:
> > Hi, Bert,
> I would suggest ruling out virus and spyware infection.
> Virus and Spyware removal and prevention
> http://home.earthlink.net/~mvp_bert/html/spyware.html >
> >> Hi Gman,
> >> enter.
> >> http://home.earthlink.net/~mvp_ber [...] rauto.html > >>
> >> Regards,
> >> http://dts-l.org/ > >>
> Regards,
> http://dts-l.org/ >
gman wrote:
> Hi, Bert,
> begun to create automatic restore points without me
> having done a thing (been very busy and wanted to wait
> understand why, unless it has something to do with having
> a password. I did not have a password before, but the
> Task Scheduler would not run a System Restore scheduled
> appears that the automatic restore points began being
> generated around that time. I do not have any restore
> task scheduled as it didn't perform the operation without
> restore point. Didn't want that; just wanted it to do it
> without me knowing.
> report this to you and, again, thank you for your
> assistance.
> gman
>> Hi,
>> gman wrote:
>>> Hi, Bert,
>>> days.
>> point every 24 hours and only when there is sufficient
>> system idle time. If the system is in use all the time
>> it is turned on, or if there is a application running
>> that causes no idle time, automatic restore points will
>> can also prevent automatic restore points.
>>> one
>> http://home.earthlink.net/~mvp_bert/html/spyware.html >>
>> and remove it from it's zip file to the desktop. Double
>> click to run it. It will show the number of hours the
>> system is set to create restore points, and allow you to
>> change it.
>>>> Hi Gman,
>>>> enter.
>>>> them here.
>>>> point
>>>> http://home.earthlink.net/~mvp_ber [...] rauto.html >>>>
>>>> Regards,
>>>> http://dts-l.org/ >>>>
>>>>> does.
>>>>> it manually?
>> Regards,
>> http://dts-l.org/
Hey, Bert.
When I was trying to SET UP the automatic System Restore feature to create
restore points automatically (such as when I logged in), XP would not let me
do it because it would ask for a password, which I didn't have. So, I
created one, which I now must type in every time I turn on the computer.
Once I did that, I could use the feature. I still don't understand why I had
to do this. Maybe it has something to do with Administrator rights. I am
not connected to a network.
Microsoft says XP is supposed to be better than ME, but I just do not find
that to be the case. I never run out of system resources with ME, and I have
a ton more stuff on that hard drive and using resources. The only single
thing I find more efficient about XP is the download speed for dialup
internet. It is definitely faster than ME, but that might be a funtion of IE
6 as I have IE 5.5 on my ME drive.
I guess I prefer things to be kept as simple as possible as that is, more
often than not, more efficient and less frustrating for the average home
user. Administrator rights? My Lord, how silly for most people, it seems.
Thanks for your imput as always.
gman
> Hi Gman,
> Thanks for the feedback. One question, what exactly did you password
> protect?
> Regards,
> http://dts-l.org/ >
> gman wrote:
> > Hi, Bert,
> > without me knowing.
> > assistance.
> > gman
> >> Hi,
> >> gman wrote:
> >>> Hi, Bert,
> >>> days.
> >>> one
> >> http://home.earthlink.net/~mvp_bert/html/spyware.html > >>
> >> change it.
> >>>> Hi Gman,
> >>>> enter.
> >>>> them here.
> >>>> point
> >>>> http://home.earthlink.net/~mvp_ber [...] rauto.html > >>>>
> >>>> Regards,
> >>>> http://dts-l.org/ > >>>>
> >>>>> does.
> >>>>> it manually?
> >> Regards,
> >> http://dts-l.org/ >
One more question Gman, when you say "I was trying to SET UP the
feature" are you referring to setting up SR in Scheduled Tasks?
As far as System Recourses go, my experience is just the opposite.
Run Process Explorer and take a look at all the running processes and
if any one of them is taking up more cpu time than normal.
http://www.sysinternals.com/ntw2k/ [...] cexp.shtml
You will also want to look at the Startup Tab in msconfig and see what
application are starting. Some apps may be able to be removed from the
Startup Tab.
gman wrote:
> Hey, Bert.
> feature to create restore points automatically (such as
> when I logged in), XP would not let me do it because it
> on the computer. Once I did that, I could use the
> feature. I still don't understand why I had to do this.
> I am not connected to a network.
> just do not find that to be the case. I never run out of
> system resources with ME, and I have a ton more stuff on
> speed for dialup internet. It is definitely faster than
> ME, but that might be a funtion of IE 6 as I have IE 5.5
> on my ME drive.
> as that is, more often than not, more efficient and less
> frustrating for the average home user. Administrator
> gman
>> Hi Gman,
>> you password protect?
>> Regards,
>> gman wrote:
>>> Hi, Bert,
>>> having a password. I did not have a password before,
>>> one. It appears that the automatic restore points
>>> began being generated around that time. I do not have
>>> operation without the restore window popping up and
>>> asking me to create a restore point. Didn't want that;
>>> assistance.
>>> gman
>>>> Hi,
>>>> gman wrote:
>>>>> Hi, Bert,
>>>>> up the restore box when I want, such as at start up
>>>>> checked the event viewer and there is nothing there
>>>>> except that restore points were created by the system
>>>>> last few days.
>>>>> time?
>>>>> one
>>>>> wants to change something or correct spelling, the
>>>>> etc. Not a big deal, just a tad annoying due to
>>>>> inconsistent behavior between features / programs and
>>>>> use of cursor.
>>>> http://home.earthlink.net/~mvp_bert/html/spyware.html >>>>
>>>>> but I am not familiar with scripts. What do I do now
>>>>> that I have downloaded and saved them to a folder?
>>>>> LOL
>>>> to change it.
>>>>>> Hi Gman,
>>>>>> press enter.
>>>>>> them here.
>>>>>> point
>>>>>> http://home.earthlink.net/~mvp_ber [...] rauto.html >>>>>>
>>>>>> Regards,
>>>>>> http://dts-l.org/ >>>>>>
>>>>>>> does.
>>>>>>> to have XP do this automatically without me having
>>>>>>> to do it manually?
>>>> Regards,
>>>> http://dts-l.org/
