How to hook Xbox 360 to a ViewSonic monitor.
  • Handheld Gaming
  • Viewsonic
  • Xbox 360
  • Video Games
Last response: in Video Games
December 29, 2011 9:18:56 PM
Hello,
ViewSonic has DVI imput and Xbox 360 has HDMI output. Do I need a converter and will this cover the sound? Meaning do I need additional cable for sound?
More about : hook xbox 360 viewsonic monitor
December 29, 2011 11:37:21 PM
dvi doesn't have sound, so you'll need to get a converter that splits HDMI to DVI and audio
m
l
May 9, 2012 7:01:59 AM
Yes you need converter that converts HDMI to DVI audio to Enable sound in it. There are converter available which lets you to convert HDMI to DVI which you can easily find in local Electronic or General stores.
m
l
May 9, 2012 6:28:27 PM
Your other option is just to use a standard DVI to HDMI cable and the optical output on the back of your Xbox (assuming whatever source you are using for sound allows for an optical input).
m
l
