Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
ok this is it we have a few year old hp desktop and it's fubared thanks to
nasty virus "bloodhound" and we want to reformat. we have the one with the
recovery partition and no disks; the problem is that we can't get the
recovery section of puter to startup. Tried to find where to start it up
while running, and tried to crash system. When we crash the system the
recovery starts then before the program kicks in it comes up with a cutout of
a window that sais something like "not enough virtual memory" and something
about the pageing file" then it kinda like crashes again and starts up like
normal. the problem is now that we can't get a thing to start up at all now.
windows starts up automaticaly locked up and just shuts itself down after
about 15 min. please just let me know what i can do to startup in safe mode
to fix the prob. enough to destructive recovery.
Jesse, try tapping F8 repeatedly until you get a Menu. Choose Safe Mode.
"jesse" <jesse@discussions.microsoft.com> wrote in message
news:8EBED0A7-02F3-44D2-B731-8665538223EC@microsoft.com...
> of
> something
> like
> now.
> mode
If you're having problems starting the recovery process from within Windows,
click on the link in the above-mentioned site for "Recovering the system
without using Windows".
Regards,
Patti MacLeod
Microsoft MVP - Windows Shell/User
of
something
like
now.
mode
thank you rich that is part of what i need to know. lol now for how to get
this recovery to actualy start up and i'm set.
> > of
> > something
> > like
> > now.
> > mode
thank you patti but that's what i've been trying to do and it comes up with
"not enough virtual memory or the pageing file is to" and it just cuts off
like it's jut putting up part of a widow. need major help pls.
"Patti MacLeod" wrote:
> Hi jesse,
> Have a look at this information from HP's support site:
> http://h10025.www1.hp.com/ewfrf/wc [...] 7145&lc=en >
> Regards,
> Patti MacLeod
> of
> something
> like
> now.
> mode
Okay, I thought that you had only attempted to start the Recovery from
within Windows, not by invoking it outside of Windows when the computer is
first starting/restarting (and prior to loading Windows).
If you are able to boot into Safe Mode (following the instructions given to
you by Rich Barry), and the computer does not automatically lock up, the
follow the instructions in this MSKB article for the virtual memory/page
file problem:
Patti MacLeod
news:4F1A0CE1-B692-46F4-A113-E5F16872B714@microsoft.com...
with
> > Hi jesse,
http://h10025.www1.hp.com/ewfrf/wc [...] 7145&lc=en > >
Windows,
> > Regards,
> > Patti MacLeod
thanks to
the
up
cutout
> > of
> > something
> > like
all
> > now.
after
> > mode
ok we just tried to start recovery in windows and it said that the drive or
device you are trying to connect to is not available or something like that.
can i get around that one or what man i need help lol
> file problem:
> Error Message: Your System Has No Paging File, or the Paging File Is Too
> Small
> http://support.microsoft.com/default.aspx?scid=315270 >
> Regards,
> Patti MacLeod
> with
> > > Hi jesse,
> http://h10025.www1.hp.com/ewfrf/wc [...] 7145&lc=en > > >
> Windows,
> > > Regards,
> > > Patti MacLeod
> thanks to
> the
> up
> cutout
> > > of
> > > something
> > > like
> all
> > > now.
> after
> > > mode
I wonder if the "drive or device is unavailable" message is referring to the
hidden partition that contains the files to perform the recovery, or if it's
referring to the state of the hard disk itself.
If that computer has a floppy drive installed, you could run the fdisk/mbr
command, as stated in the "Recovery fails after using Fdisk to partition the
hard drive" portion of the HP Document, "Troubleshooting System Recovery
Problems in Microsoft(R) Windows XP":
http://h10025.www1.hp.com/ewfrf/wc [...] 144#N10103 To run that command, you would need a WIN98 startup floppy disk (or the set
of six XP Setup disks, from which you could invoke the Recovery Console and
run the fixmbr command). The d/loadable files to create either of these are
available from here (the link for the XP Setup Disks brings you to the MSKB
article from whence you can d/load the appropriate file):
http://bootdisk.com/bootdisk.htm For the WIN98 startup floppy disk, click on the link for Windows 98 SE,
Custom, No Ramdrive and d/load the file to hard drive (do NOT d/load the
file directly to a floppy disk, as this does NOT create the startup disk).
Once the file is d/loaded, put a formatted floppy disk in the drive and then
double-click on the d/loaded file in order to create the startup disk.
Regards,
Patti MacLeod
news:458A6DF0-4B1E-45E9-89F9-6D23E021F430@microsoft.com...
or
that.
is
to
> > file problem:
> > Small
> > http://support.microsoft.com/default.aspx?scid=315270 > >
> > Regards,
> > Patti MacLeod
> > with
off
> > > > Hi jesse,
http://h10025.www1.hp.com/ewfrf/wc [...] 7145&lc=en > > > >
> > Windows,
system
> > > > Regards,
> > > > Patti MacLeod
> > thanks to
with
> > the
the
start it
> > up
the
a
> > cutout
> > > > of
> > > > something
starts up
> > > > like
at
> > all
> > > > now.
down
> > after
safe
> > > > mode
Article ID 315270 did not work for me
On the Intel site I checked my chipset using their utility, down loaded the
appropriate "Application Accelerator" and installed it.
This cleared up the problem.
SP2 and xp repair started my little anventure into this realm.
> http://h10025.www1.hp.com/ewfrf/wc [...] 144#N10103 > To run that command, you would need a WIN98 startup floppy disk (or the set
> http://bootdisk.com/bootdisk.htm > For the WIN98 startup floppy disk, click on the link for Windows 98 SE,
> Regards,
> Patti MacLeod
> or
> that.
> is
> to
> > > file problem:
> > > Small
> > > http://support.microsoft.com/default.aspx?scid=315270 > > >
> > > Regards,
> > > Patti MacLeod
> > > with
> off
> > > > > Hi jesse,
> http://h10025.www1.hp.com/ewfrf/wc [...] 7145&lc=en > > > > >
> > > Windows,
> system
> > > > > Regards,
> > > > > Patti MacLeod
> > > thanks to
> with
> > > the
> the
> start it
> > > up
> the
> a
> > > cutout
> > > > > of
> > > > > something
> starts up
> > > > > like
> at
> > > all
> > > > > now.
> down
> > > after
> safe
> > > > > mode
