Closed Solved
PS3 Monitor Help!
I am thinking about buying this monitor http://www.bestbuy.com/site/Samsung+-+27%22+LED+Monitor+-+Black/2099051.p?id=1218309759233&skuId=2099051 to play my ps3 slim on. I need to know a few things.
1. Is this monitor compatible with a ps3 slim
2. Will the monitor preform well with the ps3 slim
3. I know I need an hdmi cable but do i need separate cables for audio
4. If this monitor is incompatible can you recommend a similar compatible monitor
2 answers Last reply Best Answer
More about monitor help
  1. Best answer
    Perfectly compatible just make sure you have a hdmi cable and some sort of audio output
  2. Best answer selected by jmolozzzz.
Console Gaming PlayStation Monitors Compatibility Video Games
