Dear Members,
I need your urgent help & advice.
I was looking to purchase the Antec P160 case to create a high end system but was wondering if it was suitable & cool enough.
The components i am going to use inside are as follows:
2 WD 10,000 rpm raptor drives
P4 3.2 HT 800 Mhz front side bus
ATI Radeon 9800 XT
1 8X DVD Writer
1 52X CDRW
& a 550 Watt enermax supply
You will notice that i am only listing the high heat generating devices, but i will be using more items inside the case, but no lights or mods, etc, etc.
I have read in some reviews that the case doesnt have enough cooling, & i have only seen this type of rig being reviewed with a P4 3.0 cpu & not a 3.2 cpu.
Also i may want to upgrade to a faster cpu in the future, therefore would this case be suitable for such a system indicated above or do you recomend another case.
Also does any one have any case, motherboard & cpu temp data on idle & full load with this case & such a system.
My last question is i was also looking at the Cooler Master Praetorian(PAC-T01-E1)case, in comparison what would you recomend for greater cooling the praetorian or the antec P160
Thanks
Golddogs
ATI Radeon 9800 XT
1 8X DVD Writer
1 52X CDRW
Thanks
Golddogs
