I will shortly be getting a new system, was going to have an Antec Sonata case, but it is on back order. I am looking for alternate case + power supply solutions. Considering an Xpider, but it is a little expensive for a case w/o a power supply. The system specs are as follows
Processor: AMD Athlon64 3000+
Sound Card: C.Labs SB Live!Dolby Dig 5.1 OEM
Hard Drive: SATA 120.0 Seagate 7200 8MB
Motherboard: AMD64 S754 GIGA GAK8VT800 Pro
Optical: DVD +/-RW Litelon LDW-451S Black OEM
Memory: Corsair CVS 400MHz DDR No-ECC 512MB C3 x 2
Video Card: Sapphire Radeon 9800 Pro 128MB
I'm trying to get case + power supply for around $150 Canadian. Options I am considering are:
I think you'd probably be alright with an Antec or other 350W power supply,b ut it won't leave you much room for upgrading,a nd as it will be running close to max load, iwll tend to run a bit hotter and louder. That being said, it will work for you if you need it to, I'd guess. Currently hae the Lanboy with the included Smart 350 Blue, running this system, no trouble:
Intel P4C 2.8GHz
Corsair 512MB PC 3200 x2
Seagate Barracuda ATAIV 40GB x2
Pioneer 16x DVD Rom
Plextor 40x12x40 CDRW
Asus P4P800 Deluxe
Asus WifiB wireless Daughter Card
Vantec Nexus Fan controller
Stock Intel HSF
Arctic Cooling VGA SIlencer
System has no power problems, power buses are rock solid on voltage. THat being said, thinking I'll get a noticable bit quieter by going with a 400 or bit bigger power supply so I'm not running so close to full load. Actually just about to go looking around to price one out.
Thx. After looking at the prices at the local computer shop, I think that I'll spend another $20 on a 400W Antec PS just to be safe. Again, thx a bunch.
