Background info:
Power supply: Antec SL350 (350 watts)
It started happening after I replaced a CD-ROM with a DVD-ROM and installed 2 extra case fans, plugged into the motherboard.
At first I thought it was a video card problem. The video signal was randomly cutting out, and freezing the computer when it did. I rebooted to get a message that the system crash was caused by the video card driver.
Later on, I discovered that it was caused by it being underpowered. The motherboard was receiving only 4.6 volts on the +5v rail. That was only the first time I looked at it. Recently, it's gone as low as 4.29 volts.
Upon reseating the ATX power connector, I noticed that four of the connectors were literally burned. The plastic around each of the four +5v connectors was blackened. Immediately following a shutdown after a crash, the connector was very hot. A voltmeter on one of the HDD power connectors, on the 5v rail, read virtually exactly 5 volts. After shutting down the computer and measuring the voltage on the ATX plug itself (while jumping the required pins to turn it on), the reading was also pretty much 5 volts, well within the +/- 5% specification.
Actual problem:
Therefore, there must be a high resistance in the plug somewhere. The high resistance accounts for both a voltage drop and the release of energy as heat.
My question is, pretty much, what do I do, and how do I prevent it from happening again?
My guess is that I'll have to replace the power supply with another, but the real question is about the motherboard, and whether or not I will have to replace it.
Any help will be appreciated....
Actual problem:
