Hello,
I'm looking to buy a iDEQ 200T with this config:
P4 2.8C
1Go RAM
1 HD SATA
1 DVD writer
Radeon 9800 Pro ICEQ (this can't be changed since i already have it)
I have several question regarding the compatibility with my graphic card :
* will there be anougth space in the case (i know that the pci and agp slot are in the right position to accept this 2 slot card but i don t know for the width etc...)
* i already read on this board that people thought the power supply won t be enough on the long run with this graphic card. Any new comment ?
* last one, is it it possible to replace the power supply with a more powerfull one ? If yes which format should i look for ? (flex atx/atx ... ?) If you know references of power supply that are compatible that would be grate.
Thanks in advance,
Quetzaco
P4 2.8C
1Go RAM
1 HD SATA
1 DVD writer
Thanks in advance,
Quetzaco
