Additional Power Supply
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Additional Power Supply
Hi, i wanted to add another power supply to my computer to connectect six hard drives and 2 cd roms. But power supply is swithed on by the motherboard. Is there any other kind of powersupply that has its own on/off switch.
thanks.
Sponsored Links
Old AT power supplies did, but some didn't work without a motherboard connected. How about simply turning on both power supplies with the motherboard? You can do that with ATX power supplies.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Reply to Crashman
where do i connect the 20 or 24 pin plug that goes into the motherboard usually, that is where the problem lies, i already have 2 power supplies of 300w each. how do i switch on the second one, that is not connected to the motherboard??
Reply to vbagaria
You wouldn't have to connect the whole thing to the motherboard for the second supply, you'd only need to connect the green wires to each other. You can get inline tap-type splicers from radio shack, they clip over two wires and have a blade inside that cuts through the insulation and connects the wires.
Reply to Crashman
- 0 +
You might check this out...it will give you a pretty good idea what to do with which wires and how to power up.
<A HREF="http://www.asusforums.org/showthread.php?s=&threadid=30" target="_new">http://www.asusforums.org/showthread.php?s=&threadid=30</A>
....WW (5.0)
Reply to _WW_
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Additional Power Supply
There are 525 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
