Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Help...can't get 5.25 drives in my case..
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Help...can't get 5.25 drives in my case..
Hello - please help if you have a sec.
I have an ANTEC p160 case.
I am having some trouble putting in the 5.25 devices with the sliders provided, namely a samsung CD drive and (worryingly) the front panel for my ANTEC truepower PSU.
With sliders attached to the side of these devices, there is simply not enough room to get them in the slots provided.
I have tried inserting from the front and the back (ahem) and have the sliders arranged with the metal flap pointing to the front and away from the device, as instructed.
Sponsored Links
Did you pull the front panel off before trying to install the drives?
<A HREF="http://www.anandtech.com/mysystemrig.html?id=23900" target="_new">System</A>
<A HREF="http://service.futuremark.com/compare?2k3=2072215" target="_new">3DMark03</A>
Reply to rook
- 0 +
..nope.
Foolish me. I was following word for word the instructions that came with the case.
Does the front come off easily?
Reply to buckmoy
- 0 +
It should just snap off. Usually, the only thing you need to do is give it a little tug.
<font color=red>Urban Geek </font color=red>
Reply to cookjei
Get a couple tow straps, hook one under the edge of your front panel and to the back of a car, the other to your power supply hole to a tree, and let 'er rip!
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Reply to Crashman
There are 1286 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
