Is this enough power?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Is this enough power?
The Case i want to buy had a 350Watt Power supply (http://www.nexustek.nl/breeze.htm) is that enough for the stuff that i want in? This is want i want in it:
-512MB x 2 (1GB) PC3500 DDR CL2.5 (OCZ EB Platinum Series)
-AMD Athlon 64 FX-53 (S939, 2.4GHz, 1MB, Boxed)
-Creative SoundBlaster Audigy 2
-Gainward GeForce 6800 Ultra PowerPack Ultra2600 Golden Sample (256MB)
-LG 16x48x, GDR8161B
-LG GSA-4120B 12x
-MSI K8N Neo2 Platinum, nForce 3 Ultra
-Western Digital 36GB (Raptor WD360GD, 10.000rpm, 8MB, SATA)
-Western Digital 73GB (Raptor WD740GD, 10.000rpm, 8MB, SATA)
<A HREF="http://www.nexusarts.homestead.com" target="_new">http://www.nexusarts.homestead.com]Half-Life2:Armed Forces</A>
Sponsored Links
That really depends on the power supply, but realistically your setup is going to be approaching the limit of even a good 350 watt power supply.
Just looking over your setup, you will be close, it may work. Overall, judging by what you are purchasing, just buy a new power supply. You can buy a power supply that is exactly like the one you get in the case except with a higher rating.
Buy a new power supply, there is no point in cutting corners on a machine like that.
My Desktop: <A HREF="http://Mr5oh.tripod.com/pc.html" target="_new">http://Mr5oh.tripod.com/pc.html</A>
Overclocking Results: <A HREF="http://Mr5oh.tripod.com/pc2.html" target="_new">http://Mr5oh.tripod.com/pc2.html</A>
Reply to Mr5oh
- 0 +
If I was you, I'd get a bigger psu.
Mobile XP 2600+ (11X200)
Abit NF7-S v 2.0
Maxtor 60GB ATA 133 7200RPM
512MB Corsair Twinx 3200LL
BBA 9800 Pro
Enermax Noisetaker 420 watts
Win98SE
Reply to Coyote
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Is this enough power?
There are 438 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
