battery Fan
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - battery Fan
Could I put a small 2 AA battery powered fan inside my case? It is a cheap one, I'm sure not shielded, but it is tiny like those on a spray/fan people use in the summer.
(There IS a good reason why I want to...)
Sponsored Links
why would you want to?
amd 2000+
gigabyte ga-7va
512mb samsung pc2700(2x256mb)
maxtor 60gb 7200rpm
LG cd-r/rw 48x24x48
soundblaster live 5.1
BBA radeon 9600xt 128mb
antec 550w true control
Reply to georgebeee
What is your good reason for wanting one?
Reply to jammydodger
Well, my wife bought me 2 fans from QVC. (They are sold out, but will get more). The fans are the soft blade ones like the water spray fan ones. Each fan has a set of 5 or six tiny leds built in a tiny strip on one blade. As the blade turns, the lights give 64 different light effects. Pretty neat. I thought it would look neat in my case (you cannot see the fan blades as it turns, just an amazing light show.
See? A good reason (if a bit tacky.)
Reply to onrecess
Well thats fair enough. I cant think of any reason it would cause problems, y do you think it will?
I was just afraid the motor (being cheap and not shielded) would make a magnetic field and play havoc. (I also am wondering whether the electronics in the fan head (light controls) will disrupt anything. That worries me less because I was afraid the motor's field might ruin something expensive. I always read a magnet would erase any disc, chip, or whatever.
Reply to onrecess
Hmmmm...well I have a 420watt power supply that has clear windows (and therefore is not very well shielded) in one computer. I also have a 100watt unsheilded subwoofer near my computer. I doubt a .5watt fan will really cause a huge problem, magnetic fields only really cause problems with hard disks and with magnets this small I doubt it will be a problem.
I dont think any computer fans are specially sheilded, but I could be wrong.
Thanks. I'll try it out. I appreciate the help.
Reply to onrecess
You were right as rain. I pulled off the case side and stuck it inside... No exploding parts, no waivering monitor, nor anything worse than a tiny bit of flying dust.
Thanks again.
Reply to onrecess
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > battery Fan
There are 1143 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
