Need for speed the run pc xbox controls
Last response: in Video Games
January 16, 2012 4:36:18 PM
i got need for speed the run pc but all the controls are in xbox 360 i cant change the setings to keybord i cant give the car gas can anyone help!
January 16, 2012 7:17:40 PM
yes. go into the gameplay settings and you can set up the controls there. at the top you should see a menu with either 360 controller or keyboard input. select keyboard input...
if you dont have a pad the game is almost unplayable, especially on keyboards that only allow 1 simultaneous keypress.
if you like this or any other racing game get a 2 stick controller, they make playing much more fun...
m
l
January 16, 2012 8:05:13 PM
Alternatively you can take it back to the shop where you bought it and tell them to shove it back up EA arse from where this ill ported pile of *** can from.
It's bad enough that they continue to port stuff so badly from console but to not even be able to change keys and if you set your controller as steering wheel you can edit the settings either having to Ctrl-Alt_Del to get out.
Take it back, get your money back this game is 'not fit for purpose'.
Only then will the developers stop porting crap and ripping off the PC crowd.
m
l
January 17, 2012 6:36:13 AM
Yes this is true. This is the worst game of NFS release. Joystick goes crazy from time to time not responding and decreasing acceleration. What a waste of money buying this.
m
l
January 17, 2012 11:51:59 AM
wow. i have had 2 CTD's in 6 or so hours. thats it... my guess is it parky about which configs it wants to run on.
m
l
July 13, 2012 9:05:27 PM
I have a controller for my pc which works with all games - witcher 2 ,Fifa 12,Nfs hot pursuit ,nfs shift,assasons creed revelations , etc.But it doesn't get detected in NFS The Run , there are only two options available ,wheel controller and keyboard. But the problem is my keyboard also doesn't work sometimes in the game menu and the biggest problem is that when i have to get out of the car,only two xbox buttons X and B flashes.But nothing work,i tried spacebar,enter , and almost every key,but didn't succeed.
m
l
