Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Is a 400W power supply enough for...
a:
Athlon 64 3200+
nForce 3 250
GeForce 6800GT (spec says I need 350W PS)
Athlon XP 1800+
Soltek SL-75DRV5
512KB Mushkin PC2100 RAM
MSI nVidia GeForce TI4600
Sponsored Links
Depends on the PSU ratings, watts aren't the most important thing, its amps. Anyways, which 400 watt PSU do you have, some will be more than enough, others will be borderline, depending on how much other stuff you have in your PC (Drives, USB devices, etc.).
Most likely it will be enough, but if you post which brand and model of PSU you have, we should be able to give you a lot better answer.
My Desktop: <A HREF="http://Mr5oh.tripod.com/pc.html" target="_new">http://Mr5oh.tripod.com/pc.html</A>
Reply to Mr5oh
heya Blatz;
I recommend you buy one of the following.
1) Antec True Power 430w or better.
2) Fotron Source 400w or better.
A generic just isnt going to cut it, the rails wont be stable, the amps will be low, and the watts wont be as advertised, what this all adds up to is a burnt out 400w generic power supply in a month or less, and it can possibly take your other hardware with it.
<b><font color=blue>Co-Founder and Administrator of Toms Hardware IRC</font color=blue></b>
<b><font color=red>
Server: hub1.oddnet.net
Channel: #Tomshardware
</b></font color=red>
Reply to XeenRecoil
There are 821 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
