P4 3.6GHz "Prescott" cooling issues
Upon deciding to build a new system I chose the ASUS P5AD2 Premium, along with Corsair DDR2 XMS2, an Enermax 600W "Noisetaker" power supply, and a P4 775 560 "Prescott" processor. I've not been able to install XP Pro because the system shuts down due to overheating during the install - the system idles at 65 degrees C. Following Intel's advice, I purchased a new case and the problem persists. Intel is now shipping me a new P4. After removing the questionable processor, upon close examination of the motherboard, I found a pin missing in the ASUS motherboards’ processor socket. ASUS tech support reviewed my situation and stated it was not anything I'd done and suggested I go back to the vendor I'd bought it from since it was still in the first 30 days following the purchase. AJUMP.COM REFUSED TO EXCHANGE THE BOARD STATING I HAD DAMAGED IT.
As for as the board goes - I believe it to be a great choice offering the best in expansion capabilities. I took months deciding upon my components. I've found ASUS tech support to be excellent. Corsair was also excellent in helping me with the correct settings for their memory.
AVOID AJUMP.COM - THEY WILL IGNORE YOU IF SOMETHING GOES WRONG AND LEAVE YOU WITH DAMAGED GOODS!
CharlieR
Austin, TX
3 answers Last reply
More about 6ghz prescott cooling issues
  1. For the record, throw the Intel heatsink/fan in the garbage when you get your new CPU and get a Thermalright XP-90 heatsink and a Panaflow H1A 92mm fan (not the M1A). Do not pass GO, do not collect $200, and definitely do not put your system together until you do this. If you have the space inside your setup, consider the Thermalright XP-120 instead (you can probably use the M1A with this monster, and have a quieter setup).
    I cannot overemphasize NOT using the supplied Intel heatsink/fan. Use either one of the above heatsinks instead. You won't regret it.
  2. Hey Exictron! Do you have a slot 775? I have one(550 3.4)but have not started to put that system together. Still working on a 478 for now. IF you do, could you tell me some of the ups and downs that you have experienced. I dont find much info on these processors! Thanks!
  3. No, I have a 478 3.2 gig Prescott. Horrible thing. I have an identical MB, and I'll be building it with a Northwood.
Power Supplies Asus Processors Components
