I've been using the same laptop for gaming/everyday activities for a little over a year now. Here are my specs:
Dell XPSL 15 501X, Windows 7
GPU: Nvidia GeForce 435M
6 GB RAM
CPU: Intel Core i7 Q740 @ 1.73 GHz
The main game I play is League of Legends, and I've never had any problem with it. Recently I started playing Skyrim. It worked fine at first but now I experience some FPS slowdown after maybe around 30 minutes of playing it, sometimes to the point of my computer shutting down. I checked Speedfan and my GPU is getting up to around 98C while I'm playing, with the processor not far behind. I played LoL some more and the GPU is getting up to low 90s now as well, with some FPS slowdown (sometimes not so bad, sometimes rendering it unplayable). I don't know if it has always gotten this hot during LoL or if this is a new thing. I tried putting an ice pack under the computer and running the games, they both dropped by around 10-12C and I didn't have any slowdown. So, my problem is presumably GPU (and/or CPU) overheating. The skyrim problem was remedied somewhat by deleting all my old saves; apparently having too many saves can worsen the problem. Still, this only helped by 3-4C. My computer runs around 60-65C baseline, when just surfing the web and such. All graphics settings are on minimum. Graphics drivers are updated all the way as well.
My questions are:
1. What, if any, steps can I take to cool down my comp so that I can run Skyrim? If a laptop cooling pad is the way to go, does anyone have any recommendations?
2. Since LoL is slowing down now whereas it never did before, is it possible/likely I have caused lasting damage to my hardware? =O
3. Another factor is that my battery stopped working a long time ago. I always run my comp on outlet power, but should I go ahead and replace my battery? The error message says that since my battery isn't working my "computer might shut down suddenly," could this be contributing to my problem?
6 GB RAM
My questions are:
