The PSU of my Dell computer needs replacement. It is a Micro ATX PSU 250 Watts. Can not find a reputable brand name in that size. Only Dell has it and they want to charge an arm and a leg for it. I refuse to pay Dell what they R asking me.
QUESTION:
Can I buy a regular ATX power Supply from a reputable manufacturer (based on TH PSU Reviews)and use it on my computer by way of drilling new assembly holes (to acomodate the bigger PSU) or the connectors are also different in configuration and size.
There is no such thing as a Micro ATX form factor power supply. Several venders sell several differently sized power supplies under that label. The most common small power supply is the SFX, followed by the PS-III (looks like a full sized power supply from the back, shorter front to rear inside the case), then there's TFX and so forth.
If you could take a picture and post it somewhere of the exact power supply you have, I could make a recommendation.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
And I think U R right..my so called MICRO ATX after measurements is only smaller by fractions of inches..but even in that case, my DELL computer provides a special SLEVE where you slide the power supply IN to put it in the proper position and that SLEVE has no room for anything bigger.
Thanks.
FOR BOOSNNOODLE:
Thanks for the site you sugest and U R right that is the same PSU my DELL uses but I can not believe that their price is almost twice the price DELL wants to charge me for a new one. And DELL price is really way too high for an older computer like this.
I am looking for a reputable brand similar to FORTRON with specs in size very close to my PSU si I can avoid buying a superexpensive PSU. Thanks
The critical dimension in this ATX PSU to fit in the aseembly sleeve of my computer is the width (the one that goes from the label side you see to the other side) and it seem's to be the same width. Only 39 dollars versus 99 dollars if I buy it from the previous site whose link I sent you before.
That's a full sized power supply. Most Dell Micro ATX cases did use the full-sized power supplies. As for the brand you're looking at:
1.) I don't see Fortron Source on the label
2.) The thing doesn't have an FSP model number
3.) I don't trust it to have anywhere near the quality of a real Forton Source (or the Sparkle Power version).
CRASHMAN..U R right..no FSP on the label.
My next choice then will be a Sparkle Power and I send you the link for you to see the unit and specs.
One critical question: as long as the power supply fits correctly in the assembly sleeve of my computer and it is P4 compliant (I have a P4 1400 megs) I should have no problems correct?
Some Dell's had part of the back blocked so you would need to make sure your power connector is in the same location (as in, top or bottom of the supply). You've already confirmed a full-sized supply fits in the sleeve, and the one you've chosen from Sparkle Power is a good unit.
