Hello, I'm having major lag spikes on Skyrim. Sometimes gameplay is smooth (25+ FPS), then poof less than 10 FPS. Though the recommended setting is set to high, I can barely even play the game properly on 800x600 lowest settings without the lag issue.
I'm using an Alienware m17x R2 with:
Win7 64 bit
Intel i7 Q740 @1.733GHz CPU
6GB RAM
Nvidia Geforce GTX 285M overclocked 900/2200 on 290.53 beta driver
I'm also trying the beta 1.4 patch for Skyrim.
I've also tried the ENB and d3d9 .dll files, disabling v-sync and turning off controller in settings.
Any ideas? Thanks
Win7 64 bit
6GB RAM
Any ideas? Thanks
