Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Linksys wireless signal fluctuates from high to low ?
Forum Wireless Networking : Wireless General Discussions - Linksys wireless signal fluctuates from high to low ?
Archived from groups: alt.internet.wireless (More info?)
Is there a reason why the Linksys wireless signal fluctuates from high
to low ?
I have placed a access point between the router and the workstation,
The work station is in the basement, prior to putting the access point
in, the signal was weak.
Should I change the transmission channel ?
Sponsored Links
>to low ?
Yes. Gravity. Most things fall from high places to low places. I
would be seriously worried if they went from low to high.
Are there any cables connected to this access point? Just placing it
between the router and the workstation doesn't do much.
Well, if it was weak before, it will probably be weak after you move
it.
I don't think that will help unless you're getting interference from
some other wireless system. Try channels 1, 6, or 11.
If that doesn't help, you might wanna disclose what problem you're
trying to solve. Your description is rather vague and useless. Also,
kindly supply what you have to work with as in the model numbers of
your equipment, how they are connected, and some clue as to the
topology (layout) as measure in feet, meters, or cubits.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831.336.2558 voice http://www.LearnByDestroying.com
# http://802.11junk.com
# jeffl@comix.santa-cruz.ca.us
# jeffl@cruzio.com AE6KS
Reply to Anonymous
There are 1038 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
