Archived from groups: microsoft.public.windowsxp.perform_maintain (
More info?)
Bonjour *shiloh_56401* :
> Whenever I try to use the disk cleanup utility, it opens with 3 bars and just
> sits there. Forever. I tried going to Start-Run-cleanmgr, but that didn't do
> anything. How can I fix this, or at least delete all my temp files? It just
> stopped working a few weeks ago. I haven't done anything to any settings that
> would cause this.
Try this :
1-
Start | Run | regsvr32.exe dataclen.dll
and check if cleanmgr.exe is OK.
2-
Don't use "Compress unused files"option
check again
3-
Try again but in Safe Mode
4-
You can also clean manually the temp files in safe mode
5-
You can used this nice tool ( a new v. 3.0 is coming soon):
http://www.buttuglysoftware.com/
6-
Also : may be the problem is not the cleanmgr but the disk...
Check in the system log for disk errors:
souce : disk
errors : 7, 41, 55,
a)
Even there is no reported errors use chkdsk to check the integrity of your
hard disk:
Windows explorer | right click on disk icon |
properties | tab "tools" | "check errors" | check both options
ok and restart your computer
or
Start | Run | cmd | chkdsk X: /F /R /V ,
Where X= disk volume
For the results in applications log:
Source : Winlogon
b)
and defrag the volumes of the HD :
Start | Run | Defrag.msc
For multiple volume defrag use this:
http://www.dougknox.com/utility/scripts_desc/defrag_all.htm
Tell us if one of those procedure fix the problem.
Claude LaFrenière [MVP]
«My Principal Design Was To Inform, Not To Amuse Thee.»
Lemuel Gulliver, The Travels (IV:12)
http://climenole.serendipia.net
