G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
Hi,
I am getting the following error:
HI-SPEED USB Device Plugged into non-HI-SPEED USB Hub. A HI-SPEED USB device
is plugged into a non-HI-SPEED USB hub.
I just bought the USB 2.0 hardware and wasn't able to install the driver. I
have checked and where it is plugged in is called "Enhanced ..." so it must
be USB 2.0. Just think the driver is wrong. I have tried 'updating driver'
but said that I had the most up to date driver already installed.
I had a look in help/ support centre and they said it was a problem with XP
but should have been fixed with SP1, SP1a and SP2. I am running SP2.
Any ideas???
Thanks
B
Hi,
Any ideas???
Thanks
B
