Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I recently swapped out my system disk for a bigger one and reimaged it from
the old system disk. I kept the old disk installed for additional user disk
space. Everything works fine, except, System Restore thinks the old system
disk partition (H is still the working system disk, and doesn't even
display the new system disk partition (C in the list of drives available
for monitoring (when I look at System Restore settings). How do I get System
Restore to recognise the C: drive as the system disk (not the H: drive) and
enable monitoring on it?
Hi Keith,
> and reimaged it from the old system disk. I kept the old
> disk installed for additional user disk space.
If I understand you correctly, the new imaged drive is now C:\ which
contains WinXP, and the new drive is now set as master, and the old
drive is set to slave, or placed on the secondary controller cable.
> doesn't even display the new system disk partition (C > in the list of drives available for monitoring (when I
Does the old disk still contain WinXP? And if so, is it dual booting?
> How do I get System Restore to recognise the C: drive as the system
> disk (not
> the H: drive) and enable monitoring on it?
Without knowing the answers to the above questions, I would suspect
there was some corruption in the changing of the disk. If this is the
case, it may be necessary to turn System Restore off, reboot the
system and enable it. The only down side to this is all existing
restore points will be lost.
When SR is back up and running you should consider not letting it
monitor partitions other than C.
Here are some tips on setting up System Restore.
Keeping System Restore Healthy
http://bertk.mvps.org/html/healthy.html
Hello Bert,
Thanks for the info.
I am not using dual boot.
I actually resolved it by reformatting what was the old system disk. I
suspect the boot partition was still there and this is what was confusing
System Restore. Having done this the new system disk (C magically appeared
on the list of drives for System Restore.
Why do you suggest monitoring only the system disk partition?
Thanks,
-Keith
"Bert Kinney" wrote:
> Hi Keith,
> > doesn't even display the new system disk partition (C > > in the list of drives available for monitoring (when I
> > disk (not
> http://bertk.mvps.org/html/healthy.html >
> Regards,
> Bert Kinney MS-MVP Shell/User
> http://dts-l.org/ >
Because usually anything on a "storage" drive or partition would not be monitored for restoration. There are files that are excluded such as documents, mp3, wma, basically anything in your documents folder. See http://www.microsoft.com/resources [...] tand.mspx.
Just my 2¢ worth,
Jeff
__________in response to__________
"Keith Evans" <KeithEvans@discussions.microsoft.com> wrote in message news:69E1EA54-047C-44C3-9F0D-DFC512FB8ADD@microsoft.com...
| Hello Bert,
| Thanks,
| -Keith
> I suspect the boot partition was still there
> and this is what was confusing System Restore. Having
> done this the new system disk (C magically appeared on
What confuses System Restore ( and causes restore point corruption)
more than anything are changes made to a system when System Restore is
NOT running.
For example, any of these scenarios could cause System Restore or
restore point corruption.
1. Any changes made in the size of monitored partitions.
2. Any changes made to the amount of monitored partitions on the
system.
3. Any changes made to files or folders that are being monitored.
If drives other than the system drive don't contain monitored files,
then there would be no reason to monitor that drive.
List of Files and Folders System Restore Monitors
http://bertk.mvps.org/html/filesfolders.html
Of if there is a chance that changes could be make to these partitions
while System Restore is not running.
