Archived from groups: microsoft.public.windowsxp.perform_maintain (
More info?)
Thanks for your help so far.
(1) Tried to register NAVUI.dll using Start | Run as below. Load library
failed-The specified module could not be found.
(2) Ran all of the suggested scans/tools below. Nothing of any note, mostly
tracking cookies.
(3) No sign of any Norton AV files in %windir%\Downloaded Programs.
Other than reformatting and re-installing, any other ideas?
Your help is appreciated.
Lorne
"Claude LaFrenière" <No_InterNUT@AntiPebkac.org> wrote in message
news:ti8bz59b9sex$.3q3puto7h110.dlg@40tude.net...
> Hi / Bonjour *Lorne* :
>> I recently updated a HP EVO D510 with pending updates and SP2. OS is XP
>> Pro.
>> All identified driver updates installed as well.
>> Strange problems after installation(s):
>> (1) Norton AV-Auto Protect was disabled. When I try to enable, receive
>> the
>> following Script Error:
>> Line: 896
>> Char: 5
>> Error: Unspecified Error
>> Code: 0
>> URL: res://C
![:p :p]()
ROGRAM~1\NORTON\~1\NORTON~1\NAVUI.dll/navstats.htm
>> All other functions work fine. Nothing (I can find) on MSFT or Symantec
>> web
>> sites for this problem. Norton AV was on during SP2 installation.
> Did Norton AV was updated for sp2 ?
> Try to register this DLL that way :
> Start | Run | regsvr32.exe NAVUI.dll
> Please note that "Auto-protect" is the most important function
> of your anti-virus ( the "on access" protection...)
>> (2) Outlook: When I open Outlook, I get the following error message:
>> "Microsoft Word is set to be your email editor. However, Word is
>> unavailable, not installed, or is not the same version as Outlook. The
>> Outlook email editor will be used instead. You don't have appropriate
>> permission to perform this operation."
> Permissions suddenly modified... strange.
>> Installed program(s) is Office Standard with Word 2003, Outlook 2003. I
>> have
>> Administrator rights and log in as such.
>> (3) InstallShield: I tried to install an application and received the
>> following InstallShield error: "The InstallShield engine (ikernel.exe)
>> could
>> not be launched. Access is denied." I have Administrator rights and log
>> in
>> as such.
> Same problem than the previous one...
>> (4) Search function: START|SEARCH "For Files or Folders" or "On the
>> Internet" do not respond. Other 3 work fine.
> Search won't work...
>> (5) Closing apps: I have a couple of apps which to not respond to
>> File|Exit
>> or ALT+F4. I have to use the Task Manager to close them.
> I'm not sure but all those problems looks like a virus infection:
> permission changed
> search won't work
> AV on access protection disabled...
> Sounds bad :-(
>> Are there settings which might have been changed/corrupted in the SP2
>> installation process? This machine had not been updated in some time and
>> required almost 20 KB updates as well as SP2.
> Normally a system with no problem before the upgrade to sp2 have no
> problem.SP2 act as a "revelator" of existing problems...
> In the case of your computer it seems there is a coincidence of the
> upgarde
> and a (suspected) infection with some malwares...
>> Any help in sourcing help or troubleshooting would be very much
>> appreciated.
>> Thanks in advance.
> Try this :
> 1- When you upgrade top sp2 the installation program create a restore
> point
> before. You can try to return to this previous point and see if there is a
> difference. (You can canceled this "roll back" too.)
> 2- Any security software are reliable at 100% :
> double check with those tools:
> "Mini- antivirus" to be runned in safe mode:
> Stinger :
http://vil.nai.com/vil/stinger/
> Avast cleaner :
http://www.avast.com/eng/avast_cleaner.html
> MS:
http://www.microsoft.com/downloads/details.aspx?FamilyI...
> Kaspersky:
ftp://ftp.kaspersky.ru/utils/clrav.com
> Anti Root-Kits
> F-Secure (beta)
http://www.f-secure.com/blacklight/
> Online scan:
> Anti-trojan:
http://www.windowsecurity.com/trojanscan/
> Anti-spy:
http://www.spywareguide.com/txt_onlinescan.html
http://store.ca.com/dr/v2/ec_main.entry25?page=FindOutW...
> Anti-virus:
www.trendmicro.com
> No more idea.
> Let us know.
> Claude LaFrenière [MVP] :-)
> «My Principal Design Was To Inform, Not To Amuse Thee.»
> Lemuel Gulliver, The Travels (IV:12)
http://climenole.serendipia.net
> Soon on
www.msmvps.com
> Bientôt sur
www.msmvps.com
