Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problem with add/remove programs
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I was going through the add/remove program wizard to remove all the AOL
applications on my computer, which worked, it uninstalled all AOL
applications without complication.
But later on I messed up on some internet configurations I had made so I
used system restore and restored it to a time before I had uninstalled AOL.
Now I see AOL applications again , so when I go to add/remove programs to
uninstall it again (AOL has its own uninstaller); AOL says it cannot find and
versions of AOL on my computer even though I see it right in front of my
face. Why is it doing this? How can I remove AOL applications for good
without messing something up?
Sponsored Links
> AOL applications on my computer, which worked, it uninstalled all AOL
> so I used system restore and restored it to a time before I had
> uninstalled AOL. Now I see AOL applications again , so when I go to
> add/remove programs to uninstall it again (AOL has its own
> uninstaller); AOL says it cannot find and versions of AOL on my
> computer even though I see it right in front of my face. Why is it
> doing this? How can I remove AOL applications for good without
They are removed,when you used system restore the files names were returned
to the add/remove program but AOHell was not reinstalled.
This is an invalid entry,when you tried to remove them again did you get a
popup asking you if you wanted to remove this entry from add/remove? If so
go ahead and click on yes,if you didn't,then remove the AOHell entry from
the registry,the link below will show you how to do this.
http://www.kellys-korner-xp.com/xp_a.htm
Mike Pawlak
Reply to map
> Mike Pawlak
MAP, so now I have erased AOL from registry but I still see folders a files
plus an icon that is on my desktop ...So is it ok to delete the files and
folders manually now?
I've already created a system restore point and backed up all registry just
incase something goes wrong so I would think it would be ok to delete the
files and folders manually...right?
Reply to Anonymous
http://groups-beta.google.com/grou [...] 0686ab1885
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:3E3FD8E3-45F4-42DE-A915-40BA2EC8995F@microsoft.com,
bjxp23 <bjxp23@discussions.microsoft.com> hunted and pecked:
> AOL. Now I see AOL applications again , so when I go to add/remove
> programs to uninstall it again (AOL has its own uninstaller); AOL says it
> cannot find and versions of AOL on my computer even though I see it
> right in front of my face. Why is it doing this? How can I remove AOL
> applications for good without messing something up?
Reply to Anonymous
- 0 +
I would delete the icon on the desktop and leave the rest for now,so long
as everything was working the way it should be.(you can always go back
later)
http://www.komando.com/tips_show.asp?showID=2730
Do some reading here
http://www.google.as/search?source [...] remove+aol
To answer your ? about deleting the folders.......I did.
When I bought my Dell it came with AOHell installed ( but I never used it) I
uninstalled it and as you found folders for AOL in C:/program files I
deleted them with no problems.
As a side note and off topic,once I installed an imaging program my worries
about things going wrong were gone.
Norton Ghost
http://www.symantec.com/sabu/ghost/ghost_personal/
True Image
http://www.acronis.com/
bjxp23 wrote:
>>> AOL applications without complication.
>> returned to the add/remove program but AOHell was not reinstalled.
>> get a popup asking you if you wanted to remove this entry from
>> add/remove? If so go ahead and click on yes,if you didn't,then
>> remove the AOHell entry from the registry,the link below will show
>> you how to do this. http://www.kellys-korner-xp.com/xp_a.htm
>> Mike Pawlak
> files plus an icon that is on my desktop ...So is it ok to delete the
> files and folders manually now?
> registry just incase something goes wrong so I would think it would
> be ok to delete the files and folders manually...right?
Reply to map
There are 1289 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
