Fifa 2010 resolution problem
Last response: in Video Games
Hello,
i installed fifa 10 on my laptop, specs : intel core i3 2310M cpu@2.10ghz, 4gb RAM Windows 7 home premium 64-bit
the problem is i get only two resolution options in the game: 800*600 and 1024*768
what should i do to get the max res for the game? the screen is cut short from both ends. its really annoying, can any1 tell me a solution for this?
z0h4n24 said:
Hello,
got this from another forum:
"You can force that resolution by creating a file called locale.ini in the FIFA 10 directory and adding this line to it: RESOLUTION = 1280x800x32( what you want)
to create the file:
Open notepad
Add the RESOLUTION line above
save the file as locale.ini in the C:\Program Files\EA Sports\FIFA 10\ directory, and change 'save as type' to 'all files' "
Related ressources
they r good... i mean i have played gta 4, nfs the run, assassins creed... they worked perfectly... the resolution problem is with fifa 10 only...
graphics card: ati radeon; res : 1366*768
well i canno't access this now, but look at this forum:
http://widescreengamingforum.com/node/11196
by what i have seen this is a common problem on fifa 2010, probably there is a patch fix or something.
Never played this game so i don't know much about this;
Ask the community
