A Networking Question
Forum Windows XP : Windows XP General Discussion - A Networking Question
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
I'm not quite sure how to phrase my question, I'm still learning
'puters, so please, bear with me.
I have two PC's; one running XP Pro S/P2 and the other, W98SE. I would
like to network them so I can use the W98 unit as a server for a
printer, and some programs. If what I understand correctly what I've
read about networking, all I need do is install a network card in each
unit, and do a direct hook up (they're both in the same room).
Also, I understand that I must set up the printer as a line unit.
Is this correct, or did I misunderstand, and over-simplify?
Any help/suggestions greatly appreciated.
TIA
Sponsored Links
"Al A. Bama" <downsouth@home.erg> wrote in message
news:2nnqb1dnm391dt2candegeofvkoqbne8v7@4ax.com...
| TIA
Have a look at www.ezlan.net you'll find your network questions answered
there. As far as "serving" applications You'd need a server OS and
applications written to be accessed in such an environment.
Doug
I'm not an MVP a VIP nor do I have ESP.
I was just trying to help.
Please use your own best judgment before implementing any suggestions or
advice herein.
No warranty is expressed or implied.
Your mileage may vary.
See store for details. :)
Remove shoes to E-mail.
Reply to Anonymous
In article <2nnqb1dnm391dt2candegeofvkoqbne8v7@4ax.com>, Al A. Bama
>TIA
I don't know what a "line unit" is, but I can tell you how to network
the computers and share the printer.
There are two ways to connect the computers to each other:
1. Directly, using a crossover Ethernet cable. A regular Ethernet
cable won't work for a computer-to-computer connection.
2. Through a hub, switch, or broadband router, using two regular
Ethernet cables.
Run XP's Network Setup Wizard on both computers. It will configure
them for networking and enable File and Printer Sharing. I've written
a web page to get you started:
XP ICS - Starting the Network Setup Wizard
http://www.practicallynetworked.co [...] tupwiz.htm
Install the printer on W98SE as a network printer. You'll need either
a CD with Windows 98 drivers for the printer or a copy of the drivers
downloaded from the printer manufacturer's web site.
I'm not sure what you mean when you say that you want to use XP Pro as
a server for some programs. Most programs have to be installed on
W98SE to run on W98SE -- you can't run them by executing files that
are stored on XP Pro. The installation process copies files to the
hard disk and creates entries in the Windows registry database.
Best Wishes,
Steve Winograd, MS-MVP (Windows Networking)
Please post any reply as a follow-up message in the news group
for everyone to see. I'm sorry, but I don't answer questions
addressed directly to me in E-mail or news groups.
Microsoft Most Valuable Professional Program
http://mvp.support.microsoft.com
Reply to Anonymous
Thanks to those responding. Will let the group know how it all turns
out.
Again, Thanks.
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > A Networking Question
There are 1255 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
