Laptop wireless problems
Forum Wireless Networking : Wireless General Discussions - Laptop wireless problems
Archived from groups: alt.internet.wireless (More info?)
For some reason one of my cetrino laptops refuses to connect to my network,
it's been working perfectly before.
It will keep comming up saying "one or more wireless networks is available,
to view a list click here etc etc..." and when I do, my network is visible
and I click connect and just does nothing, the same message will pop up
again within 2 minutes.
I've gone through all the config, changed the SSIDM the channel, the WEP
password, everything!! I've reset the router and started again. But the
laptop just won't have it. It will connect, but after a reboot or standy it
won't connect again.
I have other PCs happily connected to the same network all day long,
distance isn't the issue and I have configured lan IP reservsation but it
just doesn't stick...
please help?
Sponsored Links
"mike" <mikea@localhost.net> wrote in message
news:430f9322$0$1324$ed2619ec@ptn-nntp-reader02.plus.net...
> network, it's been working perfectly before.
> available, to view a list click here etc etc..." and when I do, my network
> is visible and I click connect and just does nothing, the same message
> will pop up again within 2 minutes.
> it won't connect again.
> please help?
perhaps the minipci card has a fault, they (Intel) are not to expensive now
so maybe worth a change. It could also be worth reloading (updating) its
firmware.
Reply to Anonymous
I had a similar problem. One of our laptops just stopped working,
while the other was fine. The other had been in a Dell warehouse being
repaired for the previous week and a half. When it came back it
worked, but there were lots of Windows Updates waiting. After a couple
days, it failed too. I suspect it to be the Windows Update that
triggered the problem, but it was fixed by updating the firmware on the
router.
I don't know what router you're using, but in the notes for the
firmware update for my netgear mr814v2 was something about fixing a
compatability issue with centrino (though my system was not centrino).
Have you tried connecting without encryption? I was able to connect so
long as I wasn't using wep.
Either way, and whatever router you're using, try getting the latest
firmware. Worked for me.
hunwalla
Reply to Anonymous
Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Laptop wireless problems
There are 1165 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
