I need to get a new case. The one I got for my P4 about a year ago is all flashy and whatnot, but it doesn't cool very well.
I need a case that has excellent cooling, and is quiet. Any suggestions? I know Zalman has this...
http://www.quietpc.ca/acb/showdetl.cfm?&DID=7&Product_ID=260&CATID=35
Anyone have any other suggestions? I think my case fails in the heat department mainly because the front cover is to busy being pretty to bother having vents to bring in fresh air. I'm not even sure what the 120mm fan I have at the front is doing...
My system is a P4 3ghz, Abit IC7, Radeon 9800pro etc. I'm going to be replacing the LED fans I have for quieter fans. The PSU should be fine. I can't remember the brand exactly but its a "TrueBlue 450" and I recall at the time that it was considered good as well as quiet (I hope)
Anyways, any help you can offer would be great, thanks!
Darkmatter
Darkmatter
