Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > 3x case fans but only 2x connectors on mobo? HELP
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - 3x case fans but only 2x connectors on mobo? HELP
Hey guys so i have the thermaltake soprano (with window) so it has 3 case fans and the Asus A8N-SLI Deluxe mobo and i was reading and apparently the mobo only has 2x connectors for case fans .... seeing as my case has 3 fans ... is there any way to hook all 3 up to the case? any help would be appreciated as id like to have all the fans running. pleas get back to me guys, thanks!
PS. quick help would be great im assebuling my system tonight!
Sponsored Links
Well, the board supports fans that are most likely the 3 pin connectors. The case fans you have may be 3 pin or 4 pin molex connectors. If they are all 3 pin connectors, you would have to buy an adapter to go from 3 pin to 4 pin. If the case fans are 4 pin, just connect the fans to the molex connectors on the power supply. See if your power supply has 4 pin molex connectors that say "Fan Only" My Antec 430 watt PSU has that, so two of my three fans are connected to them which are then thermally controled by the PSU. The other fan is also connected to the PSU but runs at full speed all the time, but that is an intake, where the thermally controled one's are exhaust.
My System:
<A HREF="http://amdgamingrig.dyndns.org" target="_new">http://amdgamingrig.dyndns.org</A>
Reply to davemar14
There are 1071 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
