Power Supply
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Power Supply
I am buliding my first computer it's a ASUS A8N SLI Deluxe, Thermaltake case with multiple fans. I was told I would need at least a 600watt power supply primarily due to the SLI. Any help would be appreciated.
Sponsored Links
What else are you going to put? 600W min seems like too high!
Nothing is as easy as it looks
Reply to dunklegend
That was exagerated, and has been reduced. A good 450 watt should work fine, if you have two power hungry cards, then a 520 watt for overhead.
<pre><font color=red>°¤o,¸¸¸,o¤°`°¤o \\// o¤°`°¤o,¸¸¸,o¤°
And the sign says "You got to have a membership card to get inside" Huh
So I got me a pen and paper And I made up my own little sign</pre><p></font color=red>
Reply to RichPLS
Fan's don't draw much juice, a good 400W power supply would likely be good for your system with a single video card, and something around 500W would be more than enough with dual video cards.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Reply to Crashman
Other then the SLI, 4 120mm fans and, some lights. But don't I have to have 2 cables to hook up the SLI cards.
Thank you
Reply to MrDas
I will be running dual video cards.
Reply to MrDas
Fortron Source 500W, Antec True Power 550W should be fine. Enermax makes something between 550 and 600W also. Sparkle Power uses Fortron Source. I'd go for something with a respected name, a 600W unit from an unreliable company will be unreliable in spite of its rating.
Reply to Crashman
THANKS FOR THE INFO, YOUR HELP IS APPRECIATED.
Mrdas / J.A.G
Reply to MrDas
In addition to the solid advice in previous posts, you might want to look at the <A HREF="http://www.newegg.com/Product/Product.asp?Item=N82E16817151024" target="_new"> SEASONIC S12-500 500W Power Supply </A>. Priced right, SLI ready (although not presently NVidia SLI certified), and highly recommended as an 80 Plus Approved unit as all the Seasonic S12 line of PSU's are. Check <A HREF="http://www.silentpcreview.com/article247-page1.html" target="_new"> this review </A> out.
"The world ends when you're dead. As long as your breathing you got more punishment in store. Stand it like a man and give some back."
Reply to Renegade87
The PSU's Crahman has suggested are very good choices. I have a Thermatake 680W and its very stable. If you decide to get one this big its a very solid buy.
Intel P4 550(3.4)@<font color=green>5Ghz</font color=green>
Asus P5AD2-E-Premium
Crucial Ballistix DDR2 667@<font color=red>DDR2 800<font color=red> DDR2 855 using 3.73EE<font color=red>
TT 680W PSU
Reply to mozzartusm
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power Supply
There are 1029 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
