The amount of heat SLI give out is a pain and it can't be mixed with the CPU waterblock.
Ah yes, you need to buy the two SLI cards with two slot design(6800Ultra&6800GT have them) so that hot air is directly exausted through the case
not sure i follow you here. what do you mean by buying the two sli cards with two slot design(6800Ultra&6800GT have them) so that hot air is directly exausted through the case. you got a link that shows me what your talking about.
i am fixing to order
<A HREF="http://www.frozencpu.com/ex-tub-23.html?mv_pc=720" target="_new"> 1/2" ID Reusable Clamp </A>
<A HREF="http://www.frozencpu.com/ex-pmp-21.html?mv_pc=719" target="_new"> Hydor SELTZ L 35 Water Pump </A>
<A HREF="http://www.frozencpu.com/ex-blc-91.html?mv_pc=718" target="_new"> DangerDen TDX 1/2" Copper Water Block - Athlon64 </A>
<A HREF="http://http://www.frozencpu.com/ex-tub-28.html" target="_new"> Tygon Anti-Kink 1/2" ID (5/8" OD) Tubing </A>
what else do i need as far as the little things?
the water block is finally in stock. i just wish the 120mm Radiator and the Reservoir were back in stock so i could order all at the same time.
Thanks
