20pin vs 24 pin power connector?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - 20pin vs 24 pin power connector?
My PSU has a 20pin power connector .. but my motherboard (DFI NF4 Ultra-D s939) has a 24pin connector on it .. will the PSU work with the MB? Can I just plug my PSU in the center, skipping the outer 2 pins on each side?? Will it work?? :)
The PSU is 450watts and brand new...
THX!!
Sponsored Links
It should have a 4 pin connector, look for it and then you should connect both. They should only fit one way.
<font color=blue>Left to themselves, all things go from bad to worse</font color=blue>
Reply to dunklegend
I beleive you should plug it on the extrme right leaving 4 slot open on the left. Not sure they might mention it on your manual.
You have a ATX v1 PSU and the mobo is atx V2.0. The extra 4 pisn are an extra 12v rail to ensure stability. Any new PSU will have it.Or thy sell adapter for 5-9$
I face the opposite problem less than 1 week ago, my mobo is 20 pin and my new PSu was 24 pins. At first I was pissed but I noticed the 4 extra pins where detachable! so it fits and its ready for my next mobo.
Anyway good luck!
Asus P4P800DX, P4C 2.6ghz@3.25ghz, 2X512 OCZ PC4000 3-4-4-8, MSI 6800Ultra stock, 2X30gig Raid0
Reply to Anonymous
Cool, thanks for the help! I think I'll keep an eye out for a good ATX2.0 PSU when the price is right :)
Reply to 3yeNerd
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > 20pin vs 24 pin power connector?
There are 1211 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
