Tom's Hardware > Forum > Mobility Networks > Verizon > VX4500 battery questions
Forum Mobility Networks : Verizon - VX4500 battery questions
Archived from groups: alt.cellular.verizon (More info?)
I'm considering buying a larger capacity battery for my VX4500. Does anyone know what the rating is for the battery that comes with the phone? Also, I've seen 1600ma batteries on Ebay that appear thicker than the original. Is 1600ma the max capacity, and can you get the leather case on the phone using the thicker battery? TIA
Sponsored Links
"Swingman" <sbt@silcom.com> wrote in message news:10utmofqo67ct7b@news.supernews.com...
Well, I've been able to answer some of my own questions <g>. The original battery is rated 950MaH. The highest capacity extended battery available on Ebay is 1700MaH. Still wonder if the case would fit, though...
Reply to Anonymous
Its tight with the aftermarket 1600mah battery in the Verizon 2pc.
leather case.
Ty
news:10uvqlfsb13va8f@news.supernews.com...
though...
Reply to Anonymous
Thanks for the reply, Ty. When you say "tight" it sounds
like you can still get it on with a little effort, yes? Do
you find the larger battery adds a significant amount of
talk time - was it worth it?
"Tyrone Jackson" <tycobb@earth.net> wrote in message
news:RXXHd.3924$8Z1.2892@newssvr14.news.prodigy.com...
> Verizon 2pc. leather case.
> Ty
Reply to Anonymous
Yea, it will still go on. As far as the battery life, I couldn't really
tell any difference between the 950mah and the 1600mah. Maybe the 1600
lasts a half day longer.
Ty
news:10v0p9rmvj547d5@news.supernews.com...
> Thanks for the reply, Ty. When you say "tight" it sounds like you can
> still get it on with a little effort, yes? Do you find the larger
> battery adds a significant amount of talk time - was it worth it?
>> leather case.
>> Ty
>> fit, though...
Reply to Anonymous
Not Ty but I think a lot of the aftermarket batteries seem to be over rated
as far as capacity. Also they seem to use less sophisticated technology with
a much lower watt density (thus requiring a larger heavier battery) than
the OEMs
Reply to george
I definitely agree, over rated big time.
Ty
"George" <george@nospam.invalid> wrote in message
news:IMKdnTVU_KI3p2zcRVn-qg@adelphia.com...
> rated
> technology with
> than
> the OEMs
Reply to Anonymous
There are 1263 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
