Archived from groups: alt.sys.pc-clone.compaq (
More info?)
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 07 Aug 2004 01:21:25 GMT, dumbneasy@aol.comDUMPQ (DUMBnEASY)
wrote:
>I have torn this damn computer apart and for the life of me can't
>find where my optional memory plug is located. I've got a 128MB
>chip here begging to be used and don't know where to stick the damn
>thing!
> 1000 thank you's and please post to my e-mail as well. I'm
> desperate!
If it is like my Armada E500, the memory slot is located beneath the
keyboard. On my machine you have to remove a screw located in the
center of the back of the laptop, then release four sliding catches
located between the groups of function keys at the top of the
keyboard. The keyboard should then tilt up and out.
Just as a reminder (and which you probably already know), the
computer should be turned off and you should touch some large
metallic object (preferably grounded) to get rid of any static
electricity charges before opening the case.
-----BEGIN PGP SIGNATURE-----
Version: PGPfreeware 7.0.3 for non-commercial use <http://www.pgp.com>
iQA/AwUBQRQ/vjMYPge5L34aEQJ5HwCePE6XmrOl02aoFBh2yDl4fAOFGvkAoO6I
yhpa3xhT+aQXcsNHabFrwmTD
=7vuM
-----END PGP SIGNATURE-----
John F. Eldredge -- john@jfeldredge.com
PGP key available from
http://pgp.mit.edu
"Reserve your right to think, for even to think wrongly is better
than not to think at all." -- Hypatia of Alexandria
