MW3 Prone Problem
Last response: in Video Games
Hi all heres the problem im facing i like to use the wheel down function on my mouse to go prone in MW3 but the problem im finding is that sometimes when i wheel down it works and other times it does like a quick duck then back up like its defined to crouch and prone on same button but it isnt i have crouch as my C button and prone as wheel down does anybody know what i have to do to get this to work ? The mouse im using is a Cyborg V3 if that helps ty
More about : mw3 prone problem
If you have prone on scroll, then I guess you musn't scroll "too much" because pressing the prone button while already in prone makes you get up and I guess it's the same with mouse scroll.
Ask the community
