Hey all (if this isn't the right spot to be asking about a problem with a PC gaming headset - let me know!)
I'm on Windows 7 x64 with a Gigabyte GA-890FXA-UD5 motherboard. I downloaded and installed the Vengeance 1500 1.1 drivers and plugged the headset in. I have no issues with the sound or the mic, however while the sound in windows is NOT muted - I hear a constant low-volume static and whine (the kind you hear from cheap USB headphones, almost like you hear your computer processing things ). The whine is off and on, it'll drone in then drone out - very high pitched but just as low volume as the constant static (sounds like pink noise).
Anyone experience this? Is there something I'm missing? When I mute all sounds it instantly disapears and goes silent, turning off mute makes it very noticeable when it comes back.
Hoping someone can point me in the right direction. Thanks
