Running WinXP Pro SP2... Have the screensaver set to go on at 10 min and the monitor to turn off at 20. Using WinAmp to play an internet radio channel while I'm not using the computer and it immediately stops when the monitor turns off. Standby and Hibernation are not set to happen.
Is there any link to the monitor powering down and losing/terminating network connectivity? I do have ZoneAlarm running, and its set to lock internet access when the screensaver comes on, but WinAmp is set as a pass-lock program and has no problems when just the screensaver is running. Drivers on the Ethernet are up-to-date.
Anybody know if ZoneAlarm or XP SP2 shut off the network when the monitor gets turned off?
Thanks...
____________________
NYAAAAAH!!
Thanks...
NYAAAAAH!!
